Gauges (Help!!)
/ Gauges (Help!!) #1
Anonymous Poster
Epic Contributor
My dealer and I have so-far not found a source for hydraulic-fluid pressure and temperature gauges. /w3tcompact/icons/blush.gif
I'm looking specifically for "electrical", as opposed to "mecahanical" gauges. In other words the "sensor" is plumbed into the hydraulic line, but the gauge itself is connected by electrical wiring, and may be mounted anywhere. I'd like 0-200(or250) degrees/0-3000psi gauges.
Can anybody help?
Thanks,
Larry /w3tcompact/icons/smile.gif
/ Gauges (Help!!) #2
Larry, did you try Grainger supply or McMaster Carr? Either one should have something you can use /w3tcompact/icons/smile.gif
/ Gauges (Help!!)
Thanks Rob,
I visited both sites, along with some others from a web search, but can find only mechanical (pressure)gauges. There are some "electrical" temp gauges, of course.
Maybe the critter I'm looking for doesn't exist! /w3tcompact/icons/frown.gif
Larry
/ Gauges (Help!!) #4
Larry, I'm sure there is such a guage but I'll admit the sources I looked at were all mechanical above a few hundred PSI. I would check http://www.bbinstruments.com/ website. You'll probably have to call them, explain what you are looking for and get their advice. Good Luck!
Larry...
/ Gauges (Help!!) #5
We use a lot of pressure transducers/signal conditioning/data aquisition hardware here at work, but it's all instrument grade ($$$) stuff. For that kind of stuff try Omega or Fisher Scientific. Who knows, maybe they have an "economy" line /w3tcompact/icons/smile.gif
2020 John Deere 6120M (A62180)
2020 John Deere...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Bale Ring (A66408)
Bale Ring (A66408)
