Gator XUV, how do you remove fuel filter?
   / Gator XUV, how do you remove fuel filter? #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
JD 620i, fuel lines at the filter have some connector that I am not familiar with. Does it take a special tool to remove?
   / Gator XUV, how do you remove fuel filter? #2
Do you have a picture? The 850D is very simple and takes minutes at most. I thought they were both the same?
Like this
   / Gator XUV, how do you remove fuel filter? #3
you push the tabs and pull it out...
It has a spring loaded clip. I found a tool made to insert into it and it releases.
Thanks for the info.
   / Gator XUV, how do you remove fuel filter? #5
i just push them with my fingers and pulled apart.....glad you got it...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
