gator starter
   / gator starter #1
alanroberts
I have a HPX diesel Gator. Sometimes the starter does not engage, it just whirrs as if the starter has not engaged the flywheel. What is the problem or cure? Any ideas please.
   / gator starter #2
It sounds like the starter solenoid is not kicking the drive out far enough. Could be bad starter, or low battery voltage. Check the battery and all the connections including grounds and try again. Then it would likely be bad starter.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2021 TAKEUCHI TL12V2 SKID STEER (A52705)
2021 TAKEUCHI...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A55787)
2025 Single...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
