Gator Problem
   / Gator Problem #1
S. Shaner
Near Pittsburgh, PA
JD 2720, 2305 (sold) JD 797 Zero Turn, Gator XUV, Gator Compact
Hi.
For the past couple weeks my new, less than a year, 855D Gator has been losing the charge in its battery when sitting for more than a day or two. i figured the battery was the culprit, replaced it, but same issue. something is slowly draining it down when it sits.
Any thoughts?
thanks,
Steve
   / Gator Problem #2
There is really no way to diagnosis this over the internet; however, the gator has several relays which could be sticking in the own position
   / Gator Problem #3
Hook up a light between the battery ground post and the ground cable after it is removed. If the light glows, then there is a short somewhere.
Then you can move wires around to see if you can locate where the short is at, and/or remove some wire couplings to isolate relays and switches to locate the problem.. hopefully.
When the light goes out, you have freed up the drain and can decide the next step for fix or replacement.
   / Gator Problem
Thanks. Good direction. i will follow through later today.
Steve
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
Light Tower (A52377)
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
3 point Woven Wire Rack (A53117)
3 point Woven Wire...
