Gator hpx tail gate rattle
   / Gator hpx tail gate rattle #1
RollTideRam
Hartselle, Alabama
Kioti DK 4710 Cab
Anyone else on here have this. I checkes with the dealer and they did not know of a fix. Emailed Deere and have not heard back.
It is coming from the hinge on the tailgate. One side is tight, the other side has about 1/16 inch of play and at part throttle rattles pretty good. I had hoped deere would fix it, but I may have to myself. JC
   / Gator hpx tail gate rattle #2
On the hinge end there is a short piece of the hinge rod that sticks out maybe a half inch or so. This should have a piece of rubber around it. On mine it would rattle if that rubber was missing.
dsb
   / Gator hpx tail gate rattle #3
Mine did when I first got it before the dealer had installed any accessories but after the bed liner was added it stopped.
   / Gator hpx tail gate rattle #4
go to the hardware store buy a piece of rubber and glue it to the tail gate that way when you close it the rubber gets sqeazed in between the bed and the tail gate . problem saolved for under 3 bucks.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
BIG BED 4' ROTARY MOWER (A57192)
BIG BED 4' ROTARY...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
378721 (A54865)
378721 (A54865)
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2025 JMR 66in Root Grapple Bucket Skid Steer Attachment (A55851)
2025 JMR 66in Root...
