Gator G5 blades for GR
   / Gator G5 blades for GR #2
392-047 is the part number for the blades for your mower with the 11/16 center hole.
Thanks for that info.Looks like a closer fit.Not many sellers and no complete specs anywhere that I can find.Where did you come up with this part number?
Thanks.Took a while to navigate that catalog but I found the listing.Not quite to spec at 3" wide but the thickness is correct at .250.These are the G6 blades.Got a set ordered.I went ahead and tried the ones I got.Made bushings from 3/4" CPVC and shaved the blade ends a little as the were hitting each other.They cut nice and the clippings were definitely shorter.
   / Gator G5 blades for GR #6
Locknut, please keep us updated. Thanks! Philip.
The place I ordered the correct G6 blades cancelled the order and refunded the paypal,so I'll keep running these G5's.I ordered some 4130 tubing from McMaster Carr that makes a perfect bushing-7/8 OD/.709ID-. I picked up a vacant lot job close by that hadn't been mowed this year.Very dense and about a foot tall.Had to raise the deck to transport height-5-1/2"- to cut it.The blades do a super job with the clippings.I'm impressed.
   / Gator G5 blades for GR #8
Yep-Gator blades are great,especially in fall for the leaves. I had them for my GR2100(54"deck),then I bought some for my Cub-but Oregon doesn't make them for my deck,so I ended up getting "Extreme" blades from the dealer-same style as the Gator blade.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
