Gator G5 blades for GR
   / Gator G5 blades for GR #2
392-047 is the part number for the blades for your mower with the 11/16 center hole.
Thanks for that info.Looks like a closer fit.Not many sellers and no complete specs anywhere that I can find.Where did you come up with this part number?
Thanks.Took a while to navigate that catalog but I found the listing.Not quite to spec at 3" wide but the thickness is correct at .250.These are the G6 blades.Got a set ordered.I went ahead and tried the ones I got.Made bushings from 3/4" CPVC and shaved the blade ends a little as the were hitting each other.They cut nice and the clippings were definitely shorter.
   / Gator G5 blades for GR #6
Locknut, please keep us updated. Thanks! Philip.
The place I ordered the correct G6 blades cancelled the order and refunded the paypal,so I'll keep running these G5's.I ordered some 4130 tubing from McMaster Carr that makes a perfect bushing-7/8 OD/.709ID-. I picked up a vacant lot job close by that hadn't been mowed this year.Very dense and about a foot tall.Had to raise the deck to transport height-5-1/2"- to cut it.The blades do a super job with the clippings.I'm impressed.
   / Gator G5 blades for GR #8
Yep-Gator blades are great,especially in fall for the leaves. I had them for my GR2100(54"deck),then I bought some for my Cub-but Oregon doesn't make them for my deck,so I ended up getting "Extreme" blades from the dealer-same style as the Gator blade.
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
