gator fenders
   / gator fenders #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
i finally got around to the fenders . i got all the parts cut out and i should have them put together in a few days .i'm thinkin of putting the tail lights in the fenders . when they are done i'm gonna make another set and put them on ebay just incase anyone wants a set .as for as the price goes if you gotta ask you can't afford them .lol just jokin can't make a price yet but they will be over 200.00 for sure for a set with the led tail lights.
   / gator fenders #2
So, have you got any pics yet?
-Funkster-
   / gator fenders
i'm trying to upload them but for some reason they just won't go. i'm about 3/4 of the way finished with one right now . they pretty much look just like the stock ones do but mine are a bit wider and they will have the lights molded into them.
   / gator fenders
ok i finally got them to upload. now remeber they are not finished . i still need to add about 2"to the rear end for the lights and about 1"to the front end. and i need to drill some holes for the mud flaps in the front. they will look better with a good caot of paint too. so what ya'll think??
   / gator fenders #5
Great looking product! Not related to the fenders, but I have a 2004 Gas HPX 2WD that has had starting problems since it was new. It takes full choke and about half throttle to start and keep running. I originally thought it was a cold weather thing, but its as bad in heat as cold. The dealer worked it a couple of times and made it better for awhile. Have you heard this problem before or know of a fix?
   / gator fenders
sounds like your pickin up trash out the tank and it's probably clogging a jet partialy. most times when you have to run them on choke that means your not getting enough fuel and for that to happen go down the line checking fuel filter.fuel pump/ and if they all check out ok then i would put money on trash bein in the tank. alot of people think ifthe filter is clean the carb is clean too but there are little particles that can pass through the filter and stick into the carb and cause all kinds of stuff to go wrong i would bet your problem is in the carb. if it's not a clogged jet then i would say the float is probebly sticking . but i think it might be the jets.
   / gator fenders #7
Good job Tommy. The way my wife seems to like to drive through mud at soccer games, maybe I ought to buy a set to put on her Acura. :eek: :D
   / gator fenders
no you just need to get her one of them "range rovers" every soccer mom needs one right???lol thanks for the compliment on the fenders!!
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
FENCE PANELS (A58214)
2019 Chevrolet Tahoe (A55973)
2019 Chevrolet...
Deere 350G LC (A53317)
