dnw64
Veteran Member
Put a new battery in this spring. It was cranking slower and slower until it would only click. Assuming it was probably the charging system, tried charging and jumping, still just a click.
Removed starter and powered on the bench - the solenoid engaged but the motor wouldn't turn.
Got a new starter, installed, same thing - only a click, even with battery charger/booster* on it.
The one thing that seems strange to me is this:
Oh, and yes, the engine is free - I can turn it by hand using the clutch.
FWIW, this is one of the Gen 1 ones as far as I can tell, made in 2000.
* a "real" one, not a trickle charger - https://smile.amazon.com/gp/product/B000RFIM8U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
- Turn key to Run position
- Glow plug light comes on for the 5 seconds or so like normal
- Turn key to Start position - hear a click (holding my hand on the starter, doesn't feel like it's coming from there)
- Release key, returns to Run position, no further noise, i.e. not like the solenoid had engaged, and then retracted.
- Turn key to Off position
[*]A click/crackle - like an electrical contact break, not purely mechanical
