Gator 4x2 - headlights not working
   / Gator 4x2 - headlights not working #1
amigauser
Unionville, Connecticut USA
Kubota B2601
I just picked up a used John Deere Gator 4x2 yesterday. Everything works except the headlights. I purchased two bulbs at the local JD dealer today but that is not the problem. It doesn't seem like it is getting power to the headlight switch. I don't even have a manual yet for it so I am unsure if there are any fuses etc. that I should be looking at.
Any help is appreciated.
Thanks
   / Gator 4x2 - headlights not working #2
On the HPX, power flows from the battery through a 15 amp fuse to a set of contacts on the ignition switch, then to the headlight switch, then to headlights. I don't know if your machine is wired similarly. Check to see if you're getting juice to the headlight switch with the key on. Also, look for a PM I sent you.
   / Gator 4x2 - headlights not working #3
If it's like my Turf, then the power comes out of the ignition switch, then goes to the headlight switch. Do you have a volt meter?
I have a volt meter. The headlight switch does not appear to have power. The power dump works and I think that must feed off the headlight switch then to, correct? The wiring looks to be intact. I though maybe there was as fuse somewhere but maybe not. I will look at the ignition switch then.
Thanks.
Found the problem. I bought some batteries for my multitester and checked for 12 volts again at the switch. There was power to the switch but not from it. When I jumped the plug for the switch both headlights worked :D
Problem solved. I guess I will be visiting the local JD dealer on Monday for a new headlight switch.
Thanks everyone for your suggestions.
Spirit scooter (A55787)
Spirit scooter...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
