Gate welding idea
/ Gate welding idea #1
BMan2005
Platinum Member
GA
17' New Holland Workmaster 60 & 02' Kubota L3000F
Went to pick up some steel from a scrap yard for a cheap project and found two big steel post. So it got me to thinking about putting up a gate on a piece of our property. He had a large stack of the rectangular tubing that's used for shelf stands in Warehouse's and figured I could use this to make my gate. The pieces are 12 feet, I would cut to 10' and make two gate for a 20' entrance. My question, this stuff is 1/16" or 16 gauge. Is that thick enough to support it's weight 10' out from the hinge?
/ Gate welding idea #3
Those orange pallet racking LOAD BEAMS would not be the best choice for your gate. They are designed for HEAVY vertical loads and because of their formed and folded construction will rust out quickly outdoors.
I'd look around his yard for something else. IMHO of course....
/ Gate welding idea
Thank ya sir, that's what I was looking for. I'll abandon this idea.
/ Gate welding idea #5
Agree that those aren't the ideal material for a gate due to the irregular shape. If you don't mind scabbing material together, one could make some pretty stout barrier arm style gates with three of them though.
/ Gate welding idea #6
The pallet rack beams are tack welded in spots along it's folded seam. It will lose its shape (slightly) where you cut it to length unless you cut next to a tack.
/ Gate welding idea
You know what they are for sure. I was going to run a few more tacks down it when I noticed that. Think I'm going to just find something else to use now though since you said they will rust away fast outdoors.
/ Gate welding idea #8
I used some of those exact same pieces when building a shed a couple years ago. I wouldn't hesitate to use them for a gate, just put the seam at the bottom and drill a small hole in the bottom side of them to let out any moisture that may get in.
As far as sag, if you put an angle brace from the top of the outside to the bottom of the inside of the gate you won't have a problem. If you do get sag it will more than likely be the posts settling in.
/ Gate welding idea #9
Not sure what the cost is for the scrap material, but you can buy this 10' gate at Farm and fleet for $70, and it comes with hardware to hang it. I priced raw fence material (round 1-5/8" tubing) at a local fence place, they would cope the ends for me as part of the price, and just the material ended up being about the same price as a farm and fleet gate. Of course the fencing material was heavier gauge, but it was also galvanized so it was a pain to prep and weld. You would almost have to miter the corners on that scrap material, otherwise the profile of the material won't allow an easy way to fit the corners for welding.
/ Gate welding idea #10
....As far as sag, if you put an angle brace from the top of the outside to the bottom of the inside of the gate you won't have a problem. If you do get sag it will more than likely be the posts settling in.
Exactly. If the gate itself doesn't sag, the posts settle sideways.
/ Gate welding idea #11
Gates always sag. I'd put some wheels on it.
My gate is made of 14 gauge 2” square tubing, is 16’ Long and hasn’t sagged a quarter inch in the 7 years it has been there. It swings over a concrete driveway and the gap is the the same all the way across just like when it was installed. It has an electric opener also and gets Used a lot. It isn’t rocket science to design a gate that won’t sag and if you use a stout hinge post and anchor it deep with a lot of concrete it won’t lean either. Mine is about 5’ deep with around 1000 lbs of concrete.
/ Gate welding idea #12
True enough bdog. All about sizing for stiffness and properly anchoring. A supporting wheel makes for a lighter cheaper solution but then you need a level surface for it to track. Personally I like the slider/track design vs. swinging if it will fit the situation. Currently, I am wrestling coming up with a design for the front of my driveway. Ears on.
/ Gate welding idea
I did ditch the idea using the thin wall pallet racks. He had a big stack of 2x2" 3/16" angle iron 10' long I snagged up about 500lbs of. Figured I could use it for various projects and going to build the gates out of it. Going to have twin 10' gates and adding galvanized horse panel inside the gates. Also snagged some 6" metal pipe for post with 3/8" a
Walls.
Appreciate the advice guys.
/ Gate welding idea #14
I would recommend putting a top on your post, so 50 years from now it doesn't rust off at ground level, from the inside.
/ Gate welding idea
Already done :). It'll be a bit before I get the gates built and installed, several other projects and priority's ahead of them, but I have the material now so when I catch a break I can jump right on it.
2009 MACK GU713 DAY CAB (A63569)
2009 MACK GU713...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
Bobcat 72" Rotary Cutter (A64047)
Bobcat 72" Rotary...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
