Gate Post Removal
   / Gate Post Removal #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I had little luck removing my own stump, so I took a shot at removing a neighbors gate post. The post was sunk about 3 feet into the ground and had about 300 to 400 pounds of concrete on it. The neighbor had wiggled it with his small SUV but could not get it out. I first thought about using the trencher, but it is in the loft and a little hard to get to. I took the 4 in 1 bucket, lowered it over the top of the post and clamped down. I moved it back and forth and lifted and wiggled from several directions. It came up some, so we dropped an old piece of concrete in the hole to keep it from falling back in. Then I tried pulling it from the back of my 422. It did not go far. I then wrapped the strap around the post and the bucket and lifted and pulled at the same time. The neighbor used a digging bar (not shown in the pictures) to pry some and the post came out. I then dragged it about 600 feet to the burn pile. See attachments.
Bob Rip
   / Gate Post Removal
The post supported a gate about 15 feet long.
Bob Rip
   / Gate Post Removal
The camera came out a little late. The pictures were taken by the neighbors wife.
Bob Rip
   / Gate Post Removal
Another shot
Bob Rip
   / Gate Post Removal
Hauling it away.
Bob Rip
   / Gate Post Removal #6
Ooooo, that's a big one! /forums/images/graemlins/grin.gif
I had some concrete pieces like that at our children's school. I used the forks by jamming them into the ground under them and prying up all around. Bent the forks a bit, but got it out. However, I did not have a 2' post at the bottom of my pieces. /forums/images/graemlins/wink.gif
   / Gate Post Removal #7
<font color="red"> Amazing what you can accomplish when you have a good head on your shoulders, and a good machine under your butt!! </font>
   / Gate Post Removal #8
Man, I'd be careful getting the rear end that far off the ground! You don't want to end up on your side. Plus the most weight (and thus lifting force) would be with the rear end lower and as far from the front tires as possible. Just my inflation-adjust $0.02. /forums/images/graemlins/wink.gif
   / Gate Post Removal
I agree. In retrospec it looks a little dangerous. It the strap had broken the rear end would fall 2 feet and maybe very suddenly.
Bob Rip
   / Gate Post Removal #10
On that note... has anyone loaded the tires (especially the rears) on their PT to add weight and improve traction? I've seen one post of weights added to the rear hitch point, but loading the tires puts the weight on the ground, with a lower center of gravity for holding them on a slope, and doesn't add stress to bearings, etc.
Or, is there a concern about increasing the strain on the wheel motors to overcome the intertia of added weight in the wheel/tire combo...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
JOHN DEERE Q820M LOT NUMBER 244 (A53084)
JOHN DEERE Q820M...
NEW Fork Extensions (A53002)
NEW Fork...
