Gasoline in Diesel
Status
Not open for further replies.
   / Gasoline in Diesel #1
farmdog
Ok I admit stupidity, but I dumpted about 3 gallons of gasoline into my almost empty tc33d
diesel tank. What do I do next? cussing and crying are not options. Thanks.
   / Gasoline in Diesel #2
Drain it and refill with a full tank of diesel..May want to drain the lines ...You didn't try to start it, did you?
No, didnt try to start it, is it OK to start if I drain and refill?
   / Gasoline in Diesel #4
If you havent started it then draining it and refilling with a full tank of diesel will be more than adequate.
   / Gasoline in Diesel #5
Agreed. Whatever minute amout of gas that is in there after you drain it will dilute. I would probably drain the lines just to be on the safe side, but that's just me.
   / Gasoline in Diesel #6
a small amount of gas mixed with diesel won't hurt anything. Drain the tank as best you can, refill with diesel and drive away.
I bought this tc33d used and without a manual. How do I drain a diesel tank. Not sure where to make the connection.
   / Gasoline in Diesel #8
Go to this site for Messicks and scroll down the page and you will see where the fuel filter and fuel lines are....after you drain the tank if it were me I would pour another gallon of diesel fuel into the tank and let it drain through as well to flush any remaining gas out ...
New Holland TC-Series Service
Thanks to everybody for the help. Drained it and got it going. Seweet.
   / Gasoline in Diesel #10
Duplicate of thread in NH O/O. No need to double post. Closed.
Status
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
EZGO (A50324)
EZGO (A50324)
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
