Gasket question
/ Gasket question #1
dwiggins
DeLand, FL
Kubota B6100
New to the forum, I have a 1980 B6100 Kubota. Hydraulic line burst at weld joint where it feeds through bolt at bottom of the pump. Tried JB Weld, on slim chance it might hold. Didn't. Bought new feeder line, bolt and copper gaskets. Question: Are copper gaskets sufficient to seal the line where bolt threads into pump or do I need to use liquid gasket or copper coat on both sides of each copper gasket?
/ Gasket question #3
Copper seal washers are perfectly adequate, no sealant should be used. The washers can be reused a time or two with good results, but copper is a soft metal and each time the banjo bolt is loosened(or removed)and retightened, some deformity of the washers occurs.
/ Gasket question
Thanks, Harry, I'll check the copper for deformities, since I've removed the bolt twice trying to stop leak before I found the crack in the pipe.
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
429888 (A61165)
429888 (A61165)
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2022 Chevrolet Trax SUV (A61574)
2022 Chevrolet...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
