Gasket gooop for a newbie
   / Gasket gooop for a newbie #1
MarlinSlayer
Collierville, TN
Ford Jubilee!
anyone use any kind of gasket goop on valve cover gasket. I have a new one and it is cork...didn't think it was necessary but thought I'd ask...
Also, pulled water pump and have new gaskets all around. do you use any goop on those? If so, what kind?
Marlin
   / Gasket gooop for a newbie #2
With a cork gasket I always use a thin coating on the valve cover only. That way the gasket is reusable the next time. Water pump I use a thin coating on both sides of a paper gasket.
   / Gasket gooop for a newbie #3
make sure its the non hardening type ...
   / Gasket gooop for a newbie #4
With the cork gasket tighten carefully ,if you over tighten they will break.
   / Gasket gooop for a newbie #5
When I worked in my cousins' Harley shop it the 60's and early 70's we used to spray a coating of aluminum paint on both sides of new cork gaskets ....
   / Gasket gooop for a newbie #6
for those cork vc gaskets, yep, some thin film will be ok and as said, don't overtighten.
For other gaskets, the permatex non hardening is fine. Just did a farmall C engine a while back using that and new fel pro gaskets. no issues so far.
Excellent! Thank you. Do you smear it all over for a thin coat on the water pump gasket or do you use a bead and let it squeeze out?
   / Gasket gooop for a newbie #8
I have always used a thin coat of Permatex... but, I am almost older than dirt, so there may be newer stuff [ but not necessary better stuff out now ] .... [[ :) ]]
   / Gasket gooop for a newbie #9
Permatex or Copper Cote both work well on a paper or felt water pump gasket. If that's what you have (paper or felt) then yes smear or brush a thin coat on both sides. For the cork gasket spread a thin bead of Permatex on the valve cover only, align the gasket on the valve cover perfectly and let it dry before re-installing the valve cover. Cork valve cover gaskets will not leak even without gasket sealer, but gluing it to the valve cover aids in installation and keeps it in place.
2018 Gatormade 20+5 Gooseneck Trailer (A53473)
2018 Gatormade...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
Guardian Power FDM-58-5S 5 speed Heavy Duty Drill (A53117)
Guardian Power...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
