gas welding carbon steel to stainless
   / gas welding carbon steel to stainless #1
handirifle
Central Coast of CA
Massey Ferguson 1010
Is there anything other than brazing that can be done to join these two dissimilar metals? It's a gas only proposition.
   / gas welding carbon steel to stainless #3
They're compatible. Just go ahead and weld it with steel filler rod.
   / gas welding carbon steel to stainless #6
I found a little, (very little) bit about welding stainless steel with O/A in one of my old books.
Tig, and SMAW are probably the two cheapest processes to get going. Mig would mean a tri-mix gas which most people don't have on hand.
   / gas welding carbon steel to stainless #7
When I worked at a cannery, all the shoots were SS. We put legs and braces on them that were mild steel. We just used a SS rod on a DC stick welder. No big deal.
Why is that?
Due to space. It's a small part and I silver brazed it before, but it didn't hold. So I am wondering if welding with the steel filler rod idea will, indeed, work?
I don't have a tri-mix gas for the mig, and would be afraid to try it. Would sil-fos work? I have tons of experience with sil-fos, but never with these two metals. I have a lot of silver solder time as well, but this did not take well to it, for some reason. Maybe it got dirty by my earlier attempts, not sure.
   / gas welding carbon steel to stainless #9
In "Normal" welding techniques, its proper to use stainless filler to make the connection between steel and stainless...not steel filler.
OK thanks, I was told by others, before, to use the silver solder.
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
