gas weld aluminum?
   / gas weld aluminum? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
ok.. just got me a decent set of torches.. am playing around with new capability of using the gas axe to cut and weld with.. previous torch was only good for brazing and soldering..
question.. can yo do aluminum with it.. if so.. any special tips or tricks?
use aluminum stick rods as filler?
soundguy
   / gas weld aluminum? #2
About 30 years ago, in a trade school welding class, I remember the instructor saying that it was possible to weld aluminum with an oxy-ac torch. He said the mixture had to be just right and the flame had to keep covering the puddle so you didn't get excess oxygen into the weld. If memory serves there was also mention of flux. This made a huge impression on me at the time as I couldn't even get the hang of puddle welding steel with the torch without winding up with the filler rod frozen to the work. Never tried it on aluminum, but I suspect somebody here has.
-Jim
   / gas weld aluminum? #3
I bought some aluminum rods at a trade show a few years ago, but they were actually aluminum rods to solder with. Have used them to repair holes in a boat, and sort of used them in brazing rod type of repair on aluminum. Held up so far but would not trust this on heavy usage. Have used aluminum rods with a stick welder with fair success but it takes some practice and move fast. If you try it you will see whaat I mean.
Bill
   / gas weld aluminum? #4
I think it would be possible to weld aluminum with oxyacetylene, but difficult to avoid burning through. With regards to gas welding aluminum, hydrogen is the preferred fuel gas, as the temp is about 2300 degrees cooler than acetylene, closer to the melting temp of aluminum. So if you were to go this route, you would need a hydrogen cylinder and a regulator for it. You need to use the right flux and filler rod. I could look up more details on the flux and filler rod in reference book if you were interested.
-Jay
   / gas weld aluminum? #5
soundguy
Yep, works fine. Get the rods from your LWS. They absorb moisture and the flux falls off so make sure you seal them up and keep them dry.
The biggest learning problem is that unlike steel turning red, yellow, white, as it heats, the Al stays silver. It's really easy to melt huge holes in the work. Al conducts heat much better than does steel so a bigger, hotter flame is required.
   / gas weld aluminum? #6
If you don't aggressively clean the metal with a stainless brush, there will be too much oxidation to weld. The metal oxide " skin" melts at 2 x's the melting point of the aluminum itself. The metal underneath will melt but the oxide skin will not change at all and pretty soon you have a big glob of molten aluminum on your feet, or lap. Clean, super clean metal ( not just "shiny") is key.
   / gas weld aluminum? #7
interesting info.. thanks guys.
makes me think stick welding aluminum may be more feasable.. :)
that or those alloy rods you use a propane torch with..
soundguy
   / gas weld aluminum? #10
There are many Aluminum Solder / Braze options out there. For Joining Thin Aluminum check out JW Harris product called ALCOR. Melts at 860 degrees and is very strong. For Filling Holes, JW Harris #52. This is the miracle rod you see at shows only 1/3 the price. There is a flux for it as well. Also CORAL is a nasty liquid flux cored rod but it works. If you use a temp stick to keep your heat under control you can use an Aluminum Stick rod mentioned above. It works well for thicker material. Clean Aluminum with a Stainless steel brush or wire wheel. (Stailness Only ) Set your torch to a Carborizing Flame to keep from over oxidizing the weld. Weld her up...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
Lockwood 480 Pecan Harvester (A55301)
Lockwood 480 Pecan...
LOT LOCATIONS (A54313)
