gas running out of Kawasaki 300 Prarie
   / gas running out of Kawasaki 300 Prarie #1
mboulais
USA
2004 Mahindra 4110
My Kawasaki is about 7 years old and recently it started leaking gas out of somewhere on the engine. It stopped leaking when I brought it home and has started again. It looks like it is running out of the air intake. I am thinking stuck float. Does this make sense. I am not a small engine mechanic, but I can learn. Any advice appreciated.
   / gas running out of Kawasaki 300 Prarie #2
Just repaired my '99 bayou 220. It was leaking gas out of the overflow tube from the carb. Thought at first it was a stuck float, but turned out to be the needle valve in the carb was leaking and not stopping the gas flow into the bowl. Replaced both the valve and the valve seat and it fixed the problem. Had to buy the whole carb repair kit for $20 just to get the parts I needed. Pretty straight forward repair in the end. It may be the same with your 300. Good luck.
Thanks for the tip. I will pick up a carb kit before I start.
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
3 Digital Picture Frames (A51695)
3 Digital Picture...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
