Gas powered pumps
/ Gas powered pumps #1
shui5612
Montreal
2013 Yanmar SC2450, 2008 Kubota ZD326, 1986 Deutz 7085
I just ordered a 2inch water pump to have around the home,
What are some attachments or "accessories" you guys recommend for it?
I'm thinking a 50ft long dump hose and a 20ft suction with a filter.
How do you guys have yours set up? Have any of you built a rack for one?
Primary use is to take water from the lake and carry water in a 1000L tote to water the road in order to have dust control and to dampen the road for compacting (gravel road).
Lastly where do you guys get your hoses?
/ Gas powered pumps #2
I put pneumatic tires to move better in mud and a handle.
Got hose at zoros
Added weight[piece of angle iron] to end of suction hose to keep it from floating
/ Gas powered pumps #3
I made a skid out of 10 ga sheet metal to go under the screen on the end of the intake hose. The screen is mounted about 4" above the skid to keep it above the bottom of the lake. I tied a rope onto the skid to pull it and the hose out of the lake. now if I could figure out a way to get the skid out into the lake without getting myself wet....:confused3:
/ Gas powered pumps #4
With a 20' intake hose, are you sure your pump with do 20' of lift?? Perhaps you won't need that much lift?
Depending on how much you are going to use it, those little cheaper pumps don't last real long... I went through several until I finally bought a Kubota built pump, it's lasted many years and still going...
SR
/ Gas powered pumps
Pump is good for 26 feet of lift but the pump will only be 1 feet above the lake I just want a 20 foot long hose in order to get into slightly deeper water.
Not planning on using it all that much. Couple of times a year at best.
Even cheaper pumps can last just a question of how careful you are with it
/ Gas powered pumps #6
I have various suction strainer arrangements. One is self made, nice and flat, with the hose coming off at an angle, so you don't suck air in shallow water.
/ Gas powered pumps #7
you might consider pvc pipe, with threaded ends. and enlarging the suction pipe to 3" or 4" pipe. and a couple pieces of "hose" between the sch 40 pipe. so the pipe bends some.
well screens can be expensive. cut slots / drill holes into end of pvc pipe. and then wrap with chicken wire. give your self 2 to 4 feet pending on how you end up slotting/drilling the holes into the end of pipe. ((be careful if you cut slots. pvc pipe and like pipe, will shatter in all sorts of pieces with exploding force and go out in all directions as you attempt to cut slots, *been there done that*))
you might consider electrical plastic fittings vs sch40 regular plumbing fittings.
--electrical fittings do not have a taper / cone shape to the threads. as a result if you get a little mud or like in the threads you can still screw/unscrew the connections some what.
--regular white sch40 pvc threaded fittings have a taper/cone shape to them. so when ya thread them together, the threads "mesh" creating a water tight seal.
--if you end up sucking some air with electrical threaded fittings, before ya get things wet, run a piece of tape around.
myself.... using what i had on hand quickly
2 milk crates, 2 1 gallon bleach bottles. some electrical fence wire, some chicken wire, and some scrap steel for weight.
drilled a couple holes into end of pipe. ran electrical fence wire through it to hold milk crates onto end, tossed steel on one side of milk crates (bottom), and wired them in, wrapped with chicken wire, and then looped some wire through it all to the bleach bottles to use as floats. so i could push it all out into the water and have the end not dig into the mud. ((bottles vanished on me, but end of pipe was not end mud))
do over if i had need again. would be drill holes in 5 foot section of pipe, wrap with chicken wire, adding some steel for weight, and toss on 3 to 4 1 gallon empty bleach bottles. or a fishing boober with a longer string attached. so i could tell were end of pipe was.
if i really wanted expense, i might get some barb fittings, and what ever cheap hose i could find. and add a couple sections of it, in between 10 foot pvc pipe. so i could have some wiggle room.
valves are rather expensive. but when you are having priming issues....
1 valve, 1 tee, 1 test plug. insert it some place on suction line, were you will be able to access the test plug and valve.
test plug = acting like a cheap valve, and place to prime suction line with some water.
if gas powered pump. not a trash pump and not able to handle solids very well. and if pump does not have a "strainer" or "leaf basket pot" in front of it. might suggest getting one. more cost though. and amount of your use. most likely not worth it. and just spend any extra time making sure you do not suck stuff up, and if it clogs, you will most likely be right there when it does clog. to deal with issues.
/ Gas powered pumps #8
I guess it depends on what your opinion of "last" is...
I went through a few and I took good care of them too, no running them dry ect....all with good cleaning and 10 hour oil changes!! On top of that, I was pumping paved parking lots, NOT mud! But then again, they were used more than a couple times a year too...
I've irrigated with my Kubota pump, it looks like it's going to last about forever!
SR
