Gas in the Oil issues
   / Gas in the Oil issues #1
PRCWI
Arpin, WI
Oliver 770, Oliver 550, Bobcat 753, Gravely Atlas JSV 3000
Hi all,
I have a Land Pride Treker utility vehicle that we've owned for 3 years now. The first year we had it I was an idiot and was running fuel in it that had up to 10% ethanol. When we purchased it the treker ran great for the first year and first winter. Right before our second winter we started having issues with it smoking (white/blue smoke) Investigation led to me discovering gas getting in the oil.
We took it in and had the engine looked at, the fuel pump was replaced as they thought that was the issue first but that didn't correct the issue, so the next was having the Carb cleaned. That resulted in the issue not being fixed and with the tuning then being completely screwed up.
Finally I just had the entire Carb replaced, and that fixed it. Ran great after that for 6+ months with no issues, started great and ran great (and no more ethanol just 93 octane with no ethanol added). :)
Then this spring the front wheel bearings/drive train went out on it and we had to park it while we saved up money to have it fixed. So it sat for 3 months this summer (outside at the service center) while we were saving up the $1500 to have it fixed. When it was repaired and we got it back it seemed fine but then after about 3 weeks the gas in the oil issue reared its ugly head again.
I cleaned the carb myself this time but that didn't help. So I am at a complete loss. When it comes to small engines I feel like the blind leading the blind. Anyone have any ideas or pointers for what to try with this? I changed the oil so its running ok at the moment but it can't be good for it to have the oil gradually diluted.
We use the thing daily and being without it's use is a real struggle especially now when its getting wet/muddy around the farm and I can't use the skid steer as much without making a royal mess.
The engine is a 20HP Honda V-Twin, model GX620K1
If anyone has any ideas on how to troubleshoot or fix it I'm open to anything. Right now I don't even know how to adjust the Carb so any input is appreciated.
Thanks,
Patrick
   / Gas in the Oil issues #2
It could be several things causing this. A hole in the float in the carb causing a continuous flow of fuel. The seat is not sealing when the float is up and letting fuel flow into the cylinder. A cracked compression ring on one of the pistons allowing gas to blow by during compression. A bad intake valve allowing fuel to be sucked by into the cylinder and down into the oil.
Well I am hoping since the issue left and then returned that it's not the compression ring. Any recommendations on how to troubleshoot to isolate the problem spot?
Also anyone have any recommendations on prefered engine/carb cleaners or gasoline additives that might help clean things up if there are issues from it sitting for a couple months?
   / Gas in the Oil issues #4
Seafoam is a good cleaner. If the problem is intermittent then the float sticking moves to the front of the line. Seafoam will clean the complete system.
Ethanol will phase separate in a month or two. Stabil helps with that. It will also form a gel scum that could be preventing the check valve from closing properly.
Ok thanks, I'm going to treat with that too, looks like good stuff from the end user vids I saw. Do you just add it to the gas or should I spray it through the carburetor too?
So a new twist, I've been on the road a lot and yesterday my wife tells me that she forgot and bought gas with ethanol the last time she took the containers in to fill up. :eek: So the last several times it's been filled up it's had gas with Ethanol in it. :thumbdown: She went to town to get "good" gas and I'm going to drain the tank and carb and run the seafoam through the carb as well as add it to the new gas. Then I'll change the oil and filter and we'll see what we get.
   / Gas in the Oil issues #7
It has a fuel pump.. Electric or mechanical?
   / Gas in the Oil issues #9
We also have a treker 4420. Have had gas in the oil but I attributed it to the fact that i changed the spring loaded choke cable to manually control cable. Because of the way they engine runs lean the choke would be left too rich and fuel would get in the oil. The dealer warned me that fuel could get in the oil when he delivered it if we held the choke out to long. Now I make sure I check the oil for fuel smell and change it if I smell any. I bought a larger main jet to install when I get around to it. Should reduce the need for running with the choke out. Rick
Ahh, I hadn't heard that, we had to replace our choke cable a while ago and the spot where it goes was broken anyway so I put in a non spring loaded choke cable. We don't usually leave it out but when it's warming up sometimes we have to or it kills. I'm also not always the one driving it so the kids may drive it more. Good to know.
I had another thought too. When I first had the issue the shop I took it too use 0w oil in it rather than 10w because they said it would be better for cold usage. I'm wondering if that has any effect too.
Good to find another user with a Treker. We really liked ours until we started having this issue and ever since it's been a real pain in the but to deal with. I'm away a lot so I need it to be reliable for my wife to use daily. They are handy little things and I love the large electric dump bed on them for hauling stuff, just wish it could haul/dump a little heavier loads. Other than that its been good for us. A little tough to find parts for but otherwise good.
Let me know when you get your larger jet installed if that makes a difference as that could be helpful. :)
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
Super Material Lift MH1000 (A52748)
Super Material...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
Kubota L3130 Compact Tractor (RIDE AND DRIVE) (A50774)
Kubota L3130...
