Oil & Fuel Gas in the diesel
   / Gas in the diesel #11
Donc.. did u get it to start.?? Loosen the bleed screw on the side of the inj. pump, by the name plate..
Operate the hand primer or spin the engine till u get fuel & no air coming from the bleeder screw & tighten the screw.
Loosen ALL 3 of the steel lines at the injectors & spin the engine till fuel squirts out & tighten.. it should start then..
IF NOT> take the fuel line off going into the back of the inj. pump.. fill the endplate up w/ fuel.. now crank the engine..
Did the fuel go down any.?? if yes, thats good, u didnt seize the pump..
IF NO, bummer, u seized the inj. pump..
   / Gas in the diesel #12
06 series Deutz tractor manuals have a chart showing how much gas to put into #2 diesel in the cold temps of winter... It was a recommended procedure...
SR
We use to add 1 gallon of gas to the trucks fuel tank (60 to 80 gallons ) in the winter....
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2016 Case IH Puma 240 (A53317)
2016 Case IH Puma...
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
405 (A52706)
405 (A52706)
