Gas in oil??
   / Gas in oil?? #1
moonstruck
Boone, NC
Kubota B7800
I have a 10 year old gas Club Car golf cart that I use as a utility cart around the farm. I checked the oil today and it is way overfull and smells like gas. It seems to run fine and I have no idea how gas got in the oil. Could it be a bad gasket???
Thanks for any help.
   / Gas in oil?? #2
Stuck float? dump the oil and gas and start over and don't blow your engine
   / Gas in oil?? #3
Usually a leaking needle and seat in the carby , in conjunction with forgetting to turn the fuel tap off when parked if it is gravity fed . I do it sometimes with my water pumps , it does something to the govenors inside as they never run the same again . Replace the needle and seat , change the oil as stated and remember to turn off the fuel when parked . This will sound like a total lie but i swear it is true . I had the same thing happen while i was delivering a load of water to a customer . I started the pump and it was running rough and surging . I stopped it and turned off the fuel and removed the drain bung in the float bowl thinking it had some water in it . I then started it , still with the bung out to run it right out of fuel and it kept running!!!! Amazed i stopped it and removed the float bowl , float and needle . Out of shear curiosity i pulled the rope again and away it went !!!! You know it was still going after i pumped all the 2000 gallons of water out of the tank . It was running purely on the fuel in the crankcase , it was a sight to see it run while i had the carby parts sitting beside it .
   / Gas in oil?? #4
Too bad you could not film it. I put that right next to the big one that got away, just as I was pulling it into the boat! HONEST!
   / Gas in oil?? #5
yea that would have been something to see. to me if it was doing that the crank case would have gone up in a big poof. but like they say stuff happens.
   / Gas in oil?? #6
It's been over 35 years ago when I had that happen with a Tecumseh engine on a lawnmower. I didn't know anything those things then, so I took it to a dealer and he told me the only way to fix it would be to replace the engine. So instead, I bought another lawnmower. I now suspect that he either knew as little as I did or just wanted to make a bigger sale than was necessary. But I had it happen to a little 3 hp Briggs & Stratton engine on a spray rig a few years ago and, as the others have said, just a small carburetor problem; easily fixed.
   / Gas in oil?? #7
Thank you Bird , i was out on a "line" for a while with that one . Fish tales indeed , strewth.. But seriously they will suck the vapour from the crank case via the breather tube in the tappet cover (i think) and just run . So while it was running i pumped the tank out rather than take the load back home with me . It now flares when working , as running with the diluted oil has done something to the governor .
   / Gas in oil??
Thanks for the replies. I think I worked it out. I called a Club Car dealer in my area and he said he was 95% sure it was simply a clogged carberator drain line. I checked and yes it was stopped up. He said just cut it off past the clog, change the oil and filter and problem solved. I did and will keep check to see if it worked.
2013 John Deere 824K Wheel Loader (A56435)
2013 John Deere...
2001 TALBERT TRI-AXLE RGN TRAILER (A58214)
2001 TALBERT...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Doyle Fertilizer Spreader (A56435)
Doyle Fertilizer...
