gas in oil line
/ gas in oil line #1
emk54b1g
ramsey, nj
snapper li153
HOW CAN GAS GET INTO THE OIL. MY TRACTOR WOULD START THIS WEEK. WE CHECKED EVERYTHING (BATTERY, CONNECTION ETC.) THEN WE CHECKED THE OIL. IT WAS OVER FULL SO WE DRAINED IT AND IT SMELLED OF GAS. DID YOU EVER HERE OF THAT?
/ gas in oil line #2
Welcome to TBN
Yes. Flooding the engine,(by constantly trying to start an engine, and using the choke which introduces more gas) will cause excess gas in the cylinders which will drain past the rings into the crankcase. Some engines with a manual pump can cause gas to bypass seals and go into the crankcase.
But please kill the 'caps lock' on your keyboard..............typing in all caps means that you are yelling at us...........and we ain't done anything to make you mad...........yet:)
/ gas in oil line
Welcome to TBN
I'm not mad just trying to find out how all that gas got into the oil area. there was a lot in it.
/ gas in oil line #4
Could be a stuck float in the carb also.
2015 TROXELL 130BBL VACUUM TRAILER (A65643)
2015 TROXELL...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2018 RoGator 1100C (A63689)
2018 RoGator 1100C...
