gas in bx2230
   / gas in bx2230 #1
DWN1
SE So Dak
3- 47 M, Kubota 2330 and Ford 4500
My bride filled our bx2230 with gas by mistake (my fault as I put gas in the diesel can...i deserve a kick in the *****) I just siphoned the fuel and will change the filter next. Do I need to change the oil and oil filter too? Any other suggestions will be appreciated. AHHHHRRRGGG!!!
   / gas in bx2230 #2
Some folks dilute their diesel with gasoline during the winter months to run better just as an example etc.
I would not worry about the crankcase oil and it should not be an issue unless you have bad rings or scored pistons.
change the filters and drain the gas from the tank and add the fresh diesel and some seafoam. It should be fine with no issues other than a little unburned gas fumes through the exhaust if it was started and then shut off.
Payment for services rendered will be accepted as Molasses cookies mailed when convenient or delivered to the Snee Hall entrance @ Cornell University for services rendered.
leonZ:thumbsup:
   / gas in bx2230 #3
What leonz says and oh, it wouldn't have happened if you had a flail mower:)
   / gas in bx2230 #4
Leonz always impresses...one smart dude. But those should be home baked chocolate chip cookies, hand-delivered, still warm from the oven...:licking: :drool: Molasses? Disappointing.
   / gas in bx2230 #5
I did that to a buddies F350 last summer. Pump at the fueling station had a yellow handle and I didn't pay attention....till the engine started sputtering, then I looked at the receipt!!!
We just drained fuel, changed the filter and the truck didn't miss a beat. I'm not saying the two engines are identical, but other than that swift kick you really do deserve to give yourself, you and the tractor should come out unharmed.
Good luck,
   / gas in bx2230 #8
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
76in Smooth Bucket with Hydraulic Swivel Attached (A51573)
76in Smooth Bucket...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
