Gas from water? - A delusion, or maybe not.
   / Gas from water? - A delusion, or maybe not. #61
O.K. folks. The name calling has started. Courteous discussion should resume or the thread will most likely be closed.:rolleyes:
   / Gas from water? - A delusion, or maybe not. #62
I think the biggest question is fundamentally one of how an alternator works, and I'm willing to be edumacated on that. There is no transmission for an alternator to my knowledge which to me implies that one of two things happens:
1. It runs on demand. When the battery level drops enough to warrant a charge the alternator will flip on, but to save fuel the alternator will turn off between charges.
2. The alternator is on all the time and probably generating pretty much the max output, meaning that a lot of the output could be wasted.
If option 1 is correct, then thermodynamic laws apply. Pick up a book, now put it down. Zero work is done, the book is in the same place, but do it enough and your arms get tired because energy is expended. It's the same principle, 2*H2O + ENERGY --> 2H2 + 02 --> 2*H2O + energy. The net effect is zero and we waste energy doing it (unless we're talking about nuclear reactions, then we can convert some matter to energy but you need a Mr. Fusion and some potassium from a banana peel for that). Here perceived mileage increases are often the result of conscious or subconscious changes in driving habits or comparing the measured new mileage to the EPA estimated old mileage. The placebo effect is indeed a strong one. There's also a good chance that tapping into the air intake or changing things around steals a ton of power and gives an actual mileage increase, but you could save a lot of money by just figuring out what side effect is causing the increase. And then, of course, there's the outright lie factor. If you're selling these you'll of course want to claim large increases and if you've bought one you don't want to admit you were taken.
If option 2 is correct, then all you're doing is converting energy that would otherwise be wasted into fuel and you may see a mileage increase, perhaps significantly. However, there are other concerns:
a. You'll be voiding the warranty of pretty much everything. Adding an explosive gas into the engine will void the powertrain, dealing with water in the engine bay will take care of the electronics, and the caustic bases they require will take care of anything corrosion related.
b. As with the guy with the Lexus above, you'll need to do some fuel management reprogramming to get that working well. With a lot of cars this may not even be possible, I looked into it for mine and a two year LEASE on the computer to program my car would cost $250,000 - and that's assuming I have the skills to make those changes. If this is something that can be tweaked using an ODB connection or if your make happens to still be easy to program you may have better luck.
c. You're reducing the capacity of the alternator. This means you could kill your battery if you've got any high-draw electronics like high beams, stereo systems,and other stuff you'd probably be better off removing if mileage is your top concern, a constant 20A draw is a lot of current.
d. You should also compare the cost and danger to simply swapping out the alternator drive pulley or belt so you can underdrive it, aftermarket performance companies have this because the alternator steals engine power but by sending more power to the wheels you should get better fuel economy. A smaller alternator may also provide even better efficiency at a cheaper price.
e. The main reason the car manufacturers wouldn't use it is because it's high maintenance. Hybrids sell because they don't get treated any differently than cars, you fill them at the gas station, they drive normally, and any routine maintenance can be dealt with at oil change intervals at the dealer. Electrics don't sell because if you run out of juice or forget to charge overnight you call a tow truck and try again tomorrow. Depending on how often this tank needs to be refilled that could be a serious issue, even if it's at fuel up gas stations don't sell distilled water so you'd need to have a reservoir big enough to last between oil-change cycles and I doubt that's practical. Plus needing to handle what's effectively drain cleaner makes it a dangerous no-no from a liability standpoint. I'm assuming that when the tank is empty nothing bad happens, in theory you have two charged plates in a lump of acrylic which is mostly harmless. If there's a chance of overheating and fire when dry, for example if the plates are flexible enough to touch when going over bumps or if the water is needed for cooling, that's another major issue.
This can be made better by allowing the capture and selective release of the gas, much like a battery in a hybrid. But then you vastly add to the complexity and price. If I had a spare vehicle I would be tempted to play with one, but I wouldn't use one on a vehicle I needed as a daily driver.
   / Gas from water? - A delusion, or maybe not. #63
I am enjoying this, & as a "better educated than most" backyard mechanic am seeing both sides of the debate (not better educated in the scholastic definition, but in the mechanical definition). Sure, the debate almost seems like a replay of "plane on a conveyor belt" with some basic misunderstanding & outright ignorance, but it is educational.
Personally I've only just been introduced to this concept about a month ago, so I haven't formed any opinions, good or bad, yet. Only thing I have now is a "wait & see" attitude as MPG claims need long term monitoring to be valid & I haven't seen where tests have been done long term (more than 2 years).
If it turns out this system really does help improve MPG, then I'll look into fitting it on one of my cars & doing my own long term test, but only after studying the system & it's requirements for weak links (first impression is electric power is the weak link & after dealing with 60's Mopars for the last 30 years I, unfortunately, know all too much about weak/under engineered electrical systems).
   / Gas from water? - A delusion, or maybe not. #64
I got bored so I calculated the rate at which water will be consumed, but high school chemistry was a long time ago!
1. I'm guessing 1.9LPM refers to the total gas production, 2*H2+O2, and not the H2 production.
2. H2 has an atomic mass of 2, O2 a mass of about 32. This means that H2 has a density of about 0.09g/L and O2 about 1.43g/L. Since there are twice as many H2 molecules the average would be about 0.53g/L.
3. This means at 1.9LPM we end up creating about 1g of gasses per minute. This equates to about a mL of water per minute. If we use a 1L (1/4 gallon) tank as these seem to be you'll use up all the water every 16.4 hours that your car is on. More realistically you'll probably want to top it off in between since I would guess that the production rate goes down the more the plates are exposed to air instead of water.
If we assume that people drive about 1.5 hours a day during the week (should cover a moderate commute plus a few side trips) and you don't want it less than half full it means that you'll probably be filling up the distilled water every week or so - excluding weekend trips. Of course, your commute and the size of the reservoir may vary but once a week isn't awful if you're willing to do this sort of thing yourself. If you want to mass produce it into vehicles you can't rely on the customer having a mechanic fill the reservoir so you need to create a distribution channel for the water/lye solution and safety mechanisms for the general population. What's unclear is if or why you need to keep using a 3% solution. In theory only the water should be extracted and the solute should remain behind so you may be able to just fill with water - this would make things easier for the end user.
Of course, this assumes STP (standard temperature and pressure). More likely they measured the volume locally above sea level (lower pressure) and at engine bay temperatures (both of which inflate the actual volume generated but this also prolongs the water source).
   / Gas from water? - A delusion, or maybe not. #65
The biggest reason that manufacturers don't put ALL their available technologies into the current vehicles is because of EPA laws . Every year or so more stringent targets are set for lower emissions . If they where to put all their techs. out on display on say , a 2008 F250 what would they do for the next round of targets ? I know for fact that truck makers do this , they always have new tech. ready for the next model , otherwise it would be pandemonium at the factory every year trying to meet the targets . It's like having money available for the house loan rather than trying to scratch it up 2 days before it's due .
   / Gas from water? - A delusion, or maybe not. #66
Ahh heck; I'm with Eddie, Just do not understand all the fancy dialog surrounding this.:D :D
But why does nor someone do a real test on all this stuff. should not be to hard should it???:confused: :confused: :confused:
Maybe we could end up with the "Philosophers stone":D :D :D
   / Gas from water? - A delusion, or maybe not. #67
By googling hydroxy I found my way to wikipedia and followed a link to another entry which gave the following information.
"Applications - Claimed
[edit] Automotive
See also: water-fueled car
Oxyhydrogen is often mentioned in conjunction with devices that claim to increase automotive engine efficiency.
Many of these claims, prima facie, violate the Law of conservation of energy. See Conservation of energy and Electrolysis of water:Efficiency. To date, none of these claims have been proven, and most have been fraudulent."
   / Gas from water? - A delusion, or maybe not. #68
Also the folowing note in the article.
[edit] Production
A pure stoichiometric mixture is most easily obtained by water electrolysis, which uses an electric current to dissociate the water molecules:
electrolysis: 2 H2O → 2 H2 + O2
combustion: 2 H2 + O2 → 2 H2O
The energy required to generate the oxyhydrogen always exceeds the energy released by combusting it. (See Electrolysis of water:Efficiency)."
   / Gas from water? - A delusion, or maybe not. #69
Simple; if it works it pays to get some proper accredited laboratory verification.:D :D :D
If it don't just keep promoting it.:D :D :D
There was fellow once I asked what mileage he got from his truck. Well, he told me he drove from A to B and over to C and back home and only used 1/4 tank of gas. He figured it got terrific mileage??:D :D :D Never did find out the distance or the amount of fuel used but so be it!:p :p
   / Gas from water? - A delusion, or maybe not. #70
It strikes me that a small emergency generator would make a good test platform. Battery charger run off gen. Other loads, resistive like heaters or incandescent lights, taylored to the gen. Measure fuel consumption with loads only, then with same loads + batt charger/battery running the electrolysis. If it even runs the same amount of time on a tank it means theres a benefit. Any volunteers?
larry
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
BUNDLE OF DOUBLE AXLE FENDER INSERTS (A54756)
BUNDLE OF DOUBLE...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
