Gas & Diesel Titans go head to head on the Gauntlet
   / Gas & Diesel Titans go head to head on the Gauntlet #11
That's not the point. The pressurized oil burner should have made short work of this test at altitude. It also used nearly as much fuel over the same course, which is echoed in the feedback from Fuelly users.
Cummins missed the mark with this motor somewhere, or the transmission calibration is out to lunch.
It's 2016 not 1990.
   / Gas & Diesel Titans go head to head on the Gauntlet #12
Hearsay Reports are that Ram actually asked Cummins to build the baby Cummins. However the performance was not up to what Ram desired nor was the fuel economy anywhere near targets Ram specified. Ram declined the option on the Cummins motor accordingly to hearsay. Nissan immediately snatched the Cummins up hoping for relevance in their declining truck market banking on the Cummins name might inject some interest.
Ram made their ecodiesel internally after the baby Cummins fell so short of their targets by a large margin.
   / Gas & Diesel Titans go head to head on the Gauntlet #13
Anyone notice the gasser had 7 gears, the diesel had 6? And the diesel never seemed to shift down, while the gasser kept grabbing gears when needed? Anyhow, good test and fun to watch.
   / Gas & Diesel Titans go head to head on the Gauntlet #14
Lots of hearsay there. The Ram, Cummins, Nissan partnership fell apart when Chrysler restructured. Nissan already had a deal with Chrysler and Cummins.
The Eco-diesel is not an in-house Chrysler engine, it's a VM Motari engine from Italy. VM and Ram have worked together before with the Jeep Liberty diesel. A different engine, but it to was a VM Motari.
   / Gas & Diesel Titans go head to head on the Gauntlet #15
How is it a sin for a gasser to gear down on a hill? It ain't gonna blowup.
   / Gas & Diesel Titans go head to head on the Gauntlet #16
You take offense to too many things too easily.:rolleyes:
I was commenting on the gasser's ability to find the CORRECT GEAR while the diesel couldn't. If you'd have watched the video and listened to the commentary, the diesel was floored and slowing down while the gasser just grabbed another gear and accelerated. They had to slow down with the gasser because they were exceeding the speed limit. The gasser won. I was rooting for the gasser.
We all know what year it is. Your endless comments about modern GDI gas engines and 2016 are unnecessary. We know about them. You're so angry you can't even tell when someone is agreeing with you! :confused3:
   / Gas & Diesel Titans go head to head on the Gauntlet #17
FWIW, I took your post the way you intended it to be taken.
The diesel was saddled with either a mis-matched transmission, or bad programming. My guess is that the gasser gets the 7 speed for two reasons:
1) Because it needs an extra gear to keep up with the diesel
2) The Aisin 6-speed was the only one available to handle the power and torque of the Cummins.
I bet the outcome would have been different had the Cummins had the same tranny setup. However, the Cummins should have had the low-end torque to pull on through.
   / Gas & Diesel Titans go head to head on the Gauntlet #18
I was kinda shocked that he had it floored and the thing just sat there at 3000 RPM and didn't shift to a lower gear. Also, was he letting it shift all by itself? Could he have pulled it into a lower gear manually? Would it have helped? I know when I drive our cars in the mountains sometimes, especially our 2013 Impala with a 6 spd, it will upshift and start slowing down, then downshift and start speeding up and it gets annoying, so I pull it into a gear manually to keep constant engine RPM and road speed. I sacrifice a small amount of fuel mileage, but I think its easier on the drivetrain VS constant shifting and its easier on the flow of traffic to hold a steady speed, too.
   / Gas & Diesel Titans go head to head on the Gauntlet #19
Okay, I will bite. Who owns VM Motari? (Italian supplier or not Chrysler owns them lock stock and barrel making that in house in my eyes).
Numerous reports out there on the web (some more credible than others) and again I said most of it is hearsay, but if that little Cummins would have been a fuel miser game changing homerun of an engine do you really think the new restructured Chyrsler would have so willingly passed on it?
Rumors even out there that Ram may eventually replace the big Cummins in the 2500 and 3500 series with their own motors, but that is only rumor right now. Regardless enough rumors exist to make the diehard Cummins loyalists a little nervous.
   / Gas & Diesel Titans go head to head on the Gauntlet #20
I think he was in auto the whole way just letting the tranny do what it wanted.. I too thought he would pull down a gear
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
2121 (A51244)
2121 (A51244)
