gas coming from carb.
/ gas coming from carb. #1
stymie222
I RAN OUT OF GAS TODAY ON MY CUB CADET 1730 KOHLER 17 HP . AFTER I FILLED IT UP IT RAN ROUGH. AFTER I PUT IT AWAY I NOTICED GAS COMING OUT OF THE MUFFLER. COULD MY FLOAT ON THE CARB BE STUCK?
/ gas coming from carb. #2
Either that, or an exhaust valve is stuck open; I've seen both. I burned down an old Snapper that had a stuck valve so be careful.
R&R the needle and seat in the float bowl, make sure your float is not holed (will be heavy and slosh with gas if it is). Drain the crankcase and refill with fresh oil before you start it; if it was the float stuck then enough gas can seep past the rings to fill the crankcase and hydraulically lock the engine when you start it next, wreaking much havoc.
If you have little or no compression when you turn it over to start it, the valve is stuck. Try the needle, seat, and float R&R first since that is easy and cheap to do.
Good luck with it.
Pete
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
(2) Corral Gates (A66408)
(2) Corral Gates...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
