Gas can fix
   / Gas can fix #3
That valve stem, what might some of the stores be that would carry it?
   / Gas can fix #5
Any auto parts store should have them. I think that Walmart even has them. It is just a standard valve stem for a tubeless tire. I picked up a couple at Orielly auto parts. I think the ones that I used are 1in long.
   / Gas can fix #6
Thanks, Mike. Already done that using a shorter valve stem that was the metal bolt on fit type. I hope the diesel doesn't dissolve the rubber interface with the container(over time that is). At 80 years old and 145 lbs, lifting 5 gallons of diesel is getting to be quite a chore. So the alterations make it go better. I also use a two foot tall stool to prop the jug on my leg on while filling.... works good rotating stored gasoline that's moved into my truck too. Mike oldballs
   / Gas can fix #7
There are a number of youtube videos on the subject, all a variation on the same theme. Apparently lots of folks have trouble with the inane EPA compliant designs.
   / Gas can fix #8
I've spilled more in a few years with the EPA cans because they don't seal tight on the tube than I did in the rest of my life. And I always capped my old cans so I doubt much evaporated. Faulty design that does the opposite of what it is supposed to do.
   / Gas can fix
Something we can all agree on... There is hope :)
   / Gas can fix #10
Are you referring to the EPA in general or just the gas can :)
2023 Top Hat Industries Cool Down Trailer (A52377)
2023 Top Hat...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
