hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,746
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
I've got an odd problem with JD garden tractor. It's an LX188 powered by a Kawasaki 17HP V-twin liquid cooled engine.
Frequently when I first start it, it will belch white smoke for the first minute or two that it runs. Sometimes it even runs on one cylinder for the initial smoke period.
I haven't noticed an appreciable drop in either coolant or oil level, but I *think* the smoke smells more like antifreeze than oil. Once the smoke burns off the tractor runs fine. Subsequent restarts will be smoke-free unless I leave the tractor for a week or so, then the first start will smoke again.
I'm guessing some sort of coolant leak into one of the cylinders. Any thoughts from the gang?
Now in case you thought this would be easy, there's actually a longer story and another problem behind this. When I first bought the tractor, during the first few minutes of operation the oil light would come on and off. We replaced the sender unit and other external parts, but the problem persisted. The dealer I bought from was a complete theif, adn JD was no better in helping. The JD phone support rep first told me that I was supposed to run the engine at full throttle from initial cold start (despite all good reason and despite what the manual says), and then to top it off he told me that they'd be happy to remove the warning light bulb if this continued to bother me.
Subsequent oil pressure tests with external mechanical guages confirmed that indeed the pressure was dropping to zero for multi second periods of time during warm up. Conclusion - the problem is real.
I finally gave up on the dealer and JD and just kept mowing my lawn finguring that I had a well documented case if the engine failed. A year or so later I found a good dealer and a service manager who took this on as a challenge. He ended up tearing down the whole engine looking for problems, but everything checked out. They replaced the oil pump and lower unit casting, and put it all back together.
Guess what? The oil light problem continues to this day (7 years later), and the smoking problem started right after I got the tractor back from the teardown repair. I've had the tractor back to the dealer since and they claim they can't find anything wrong with the tractor (what a surprise), and there is of course a new service manager.
I've just given up on these problems and am going to run the thing until it blows up at this point. JD sure isn't going to make good on it.
So I thought I'd tap the wisdom of TBN to see if anyone else had had problems like these two (which, by the way, I think are independent problems).
Any ideas?
Peter
Any ideas?
Peter
