garden tractor compression release
/ garden tractor compression release #1
bjr
Veteran Member
Eastern WA
Jinma JM354
The neighbor has probable mid ninty's JD garden tractor 2 cylinder (18-22 hp?) and he thinks briggs and straton engine. It's has starting issues, slow turning over. The engiine finally started and seems to run fine, once started. The usual trouble shooting as changing batteries and finally changing starters and still barley turns over. My old Dixon mower (single cylinder) has a automatic compression in the valve train somehow and does the same thing if the valves are out of adjustment. Could this 2 cylinder engine have a automatic compression release and be causing the hard starting? Thanks in advance. bjr
2013 Dodge Durango SUV (A66738)
2013 Dodge Durango...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
PROPANE BOTTLES (A68842)
PROPANE BOTTLES...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
5103SFL (A64553)
5103SFL (A64553)
