garden seed
/ garden seed #1
mj58
edwards mo
ford 861 ferguson to20
i need some help with my garden its a new area only worked it up two years ago and i havent had a soil test done on it the problem i am haveing is very poor germination rates with any seed you plant in it iknow about plating depth and spaceing so i try to be careful with that i never had problems like this at my old garden were i lived before i have added manure to the spot last year it got dry here last year so i just let it go i just wonder if something lacking in the soil is want it is any one have any ideas thanks mike
/ garden seed #2
Hard to say whats wrong without a test.
Do you water?
Have you added anything besides manure? What is the soil like? Clay? Have you added any sand or organics?
I usually put a layer of peat moss , vermiculite and sand and top with 7-7-7 in my garden each year. Water every day when needed. I planted a week ago and much of my garden is already up.
/ garden seed
as soon as it gets dry enough i will get that test done so far this year we havent had to water i would say the soil is a sandy loam we spread rotted cow manture on it and then goat and chicken mixed with peat moss
/ garden seed #4
Buy a PH meter (about $15) at your local supply...what is the temperature of the soil ?
/ garden seed #5
Seeds need both warmth and moisture. A lot of seed wont germinate in cold ground...exactly what types of seed wont germinate anyhow?
/ garden seed
no one close has a ph tester so i guess i will have to order one its everything i have tried to plant cucumbers radishes corn okra squash some comes up spoty and some not at all we have had a lot of rain this year so moisture shouldnt be a problem the weather has been a little cooler then normal this isnt the frist time i have planted a garden but it the first time i have had problems like this i know i need the soil test so i know exactly what it needs i just never had trouble getting some thing to grow before thanks for your help mike
/ garden seed #7
How long have you owned the property ? Do any weeds or grass grow on the garden site now ? Almost sounds like there is an herbicide carry-over problem depending on what the soil test shows. Older form of atrazine, princep, etc. if dumped on the soil would last a long time and cause germination problems, but a soil test would really help to start the search. You may want to fill several small pots with the soil, put them in a cool place like a basement and try a few seeds of various crops. Much easier to evaluate in a more controlled environment if you are having that big of a problem. Good luck.
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2016 John Deere 6155R (A64119)
2016 John Deere...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
