garden plowing
   / garden plowing #1
schalfback
Which tractor would be more suitable for plowing a garden with a brinley plow.
A allis chalmers 712S tractor or a cub cadet 1215 tractor.I would get Ag tires for better traction.Both tractors have 12 hp motors. Any help appreciated
thank you
   / garden plowing #2
Either would probably be fine with the ag tires. I think the Cubs are known for hefty rear ends. Adding weight and ribbed tires to the front will also help keep the front end in the furrow.
I have an Economy Jim Dandy thats about the same size it pulls the brinly plow just fine.
Layne
   / garden plowing #3
The Cub 1215 is a lawn tractor only, not a garden tractor, so plowing is probably too much for it. It has a much weaker transaxle in than a garden tractor. Now if you had a Cub cadet 1200, 1210 or 1250 model, these are tough garden tractors.
Even with ag tires, a 1215 isn't going to do this long before failing. It was designed for lawn duty and light work, no high drawbar loads. Not sure about the Simplicity.
   / garden plowing #4
The Simplicity 712S is a garden tractor. If you go to the Simple Tractors website you can get alot of information on them.
   / garden plowing #5
We use our Cub Cadet 1215 for plowing snow. It will push alot of snow! They are good little tractors. We put a 10 horse in it because we bought it without an engine, and it works fine for plowing alot of snow, we have never tried to put a single bottom moldboard plow on it though, you might have to weld supports on the back of the tractor to strengthen the hitch, it is a light duty hitch.
Good Luck-:)
   / garden plowing #6
I see this is a old thread. but im new :D
older cubs rule!! if it has a cast iron rear end under it. (IH built)
and 12 to 16hp. stack the wheel weights on , ag tires & chains and let-r-rip
   / garden plowing #7
good to know for the future :)
i just bought a farm and about to buy all the new equipment
dense about it so far :)
__________________
avi player
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
Ford Pickup NR (A50323)
Ford Pickup NR...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2016 Ford Fusion SE AWD Sedan (A50324)
2016 Ford Fusion...
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
