Garden Fence Project
   / Garden Fence Project #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Thought I would show what the SFO and I have been up to this week, she got her "high end: garden fence. Basically pressure treated 2x4 and 4x4 posts with 4.5ft X8 ft galvanized 4 gauge cattle fence (from 4.5 ft x 16ft panels). We got our ebay turnbuckles and aircraft wire and will put up two top wires per the neigbors deer instructions.
Only downside is that the bottom 2x4 sags so we will be attaching it to the cattle wire (probably a lockscrew).
All in under 1500 so not too bad for 24X60 layout. I wish it had been for free but never that lucky.
Carl
   / Garden Fence Project #2
Looks good! I just went through the same thing (re-located our garden) I was able to re-use most of the old fence and post, but it did make it more difficult (different slopes). Our garden slopes probably about as much as yours looks to, so I started a retaining wall at the low end made from RR ties.
   / Garden Fence Project #3
Great looking fence! I'd like to do something like that, but don't have raised beds and would like to get my tractor in and out to rototill. Haven't squared up in my mind how to have good tilling access (with room to turn around etc) and a nice permanent fence like you built! Good job! :thumbsup:
   / Garden Fence Project #4
Looks nice.
We did the same thing around both of our gardens (mainly for the dogs) and built a dog run as well using the same method (except I used 2x6s instead of 2x4s). If you use fence stables to connect the panel at strategic points to the PT lumber, it keeps the PT from warping (as much) and helps with the stability of the entire structure.
   / Garden Fence Project #5
The 2x4 on top of the cattle panels really helps it look "finished." Great place to rest a coffee cup too! :) Nice job.
I will get a closeup, but we dado'd the posts and the header and footer boards so the wire fence rides inside. I have two trashcans full of sawdust from that experience.
   / Garden Fence Project #7
That fence looks really pretty Woodlandfarms, I'm curious what you are keeping out though. In my past gardens the main pests have been deer and rabbits. It looks like rabbits can go under or through your fence, and deer over it. No disrespect intended at all, I really like the clean look of it!
   / Garden Fence Project #8
My garden pest problems are turkeys, snowshoe hares, deer, raccoons, and moose.
The turkeys like to take dust baths in the dirt and tear up the plants flopping and scratching in there.
The bunnies and deer just chow down on everything.
The raccoons are the ban of any corn.
The moose are just random. They'll take a bite of this or that, but end up stomping on more than they eat.
No bear problems....yet.
   / Garden Fence Project #9
Doc, if and when you do have a "bear problem" I'd like to see the fence you put up to stop them:D Mine field comes to mind:laughing:
   / Garden Fence Project #10
Nice fence! I need something like that so thanks for the ideas.
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A55218)
2012 New Holland...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Tires (A50322)
Tires (A50322)
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
