Garage Door Distances
   / Garage Door Distances #21
That means that they want to see 48" between the corner of the building and a window or door (including a garage door)
This means a single car garage with a 10 foot door has to be 18 feet wide instead of the normal standard 12 foot wide.
According to this my 4 stall garage would have to be 72 feet wide rather than the 52 feet I made it.
It also means that if I built an 8 foot wide storage building I could not put any doors in it.
I'm sure glad there are no building codes here in Washington county .
L . B .
   / Garage Door Distances #22
standard parking lot has 9' wide spaces.
if you assume your car is 6' wide, that would leave 3' between you and the car next to you for you to open the door.
when laying out garages shops for people. i usually show 4' between the car space and the wall. 6' if you plan on having a bench on the wall. (note thats between the car space and the wall, not the edge of the door opening)
   / Garage Door Distances #23
I oversimplified the issue. The prescriptive code (the design parameter "cookbook" that building departments can use to approve buildings absent an engineers stamp) says that the building envelope needs to have shear panels on each wall. A 4x8 sheet of osb nailed to the wall framing serves this function, provided it is not compromised by a door or a window. If 48" is undesirable, 2' 8" is suitable if it has long straps securing it to the foundation.
A long, skinny building may also need a shear wall in the middle somewhere.
Your 52' wide building probably wouldn't need more than two shear panels, at the two ends... so a grand total of 5' 4" beyond the ends of the left and right doors.
   / Garage Door Distances #24
this is why simpson and a number of other manufacutres make various shear wall items.
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2020 JOHN DEERE 3032E TRACTOR LOADER BACKHOE (A51243)
2020 JOHN DEERE...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
John Deere (A50322)
John Deere (A50322)
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
