Garage Air Mounted Lines
   / Garage Air Mounted Lines #1
dieselscout80
South Carolina
New Holland TC45DA
   / Garage Air Mounted Lines #2
Some have used high pressure rated glued together PVC piping.
IE. the same as is being used for water lines...
But looks like these kits would be pretty convenient to install.
   / Garage Air Mounted Lines #3
Are the air line kits available at like Northern Tool and Amazon a good option?
I want to run air around my garage it’s 20’x30’.
What concerns me is the lack of available parts.
It seems like you must buy a big kit more drops / connector.
You can buy individual parts from Rapidair directly. I prefer the ridge pipe style Rapidair myself, but it is a bit more expensive. Avoid PVC, it works until it doesn't. It can fail pretty spectacularly, and be dangerous is someone is nearby.
Iron or copper pipe is another option.
   / Garage Air Mounted Lines #4
Yes I agree being pressurized air any pipe would be a big hazard if it exploded, and the more volume the bigger the issue.
   / Garage Air Mounted Lines #5
I ran all mine 40 x 40 heated and cooled shop with an overhead crane in 100% black iron with multiple drops and all air lines slop back towards the compressors about 2.5 degrees so condensation runs back but even so I have ball valves at each drop.
My static pressure is 150 psi and I don't trust anything but threaded black iron. 150 psi in exploding tubing or plastic pipe equals a grenade in your face or worse and I also have employees to worry about so it was total black iron, large diameter as well. All the main runs are 1.5" pipe and the drops are 1".
Was it expensive, you bet your butt it was but lives are way more valuable in my view.
Bought all the pipe in mill lengths and threaded it myself and all the fittings I purchased from WW Grainger.
Not sure I believe PVC is a good option.
I know the pipe is rated high enough but what about the glue joints and fittings
   / Garage Air Mounted Lines #7
when i had my mechanics shop I ran CPVC. a lot stronger than plain PVC. easy to run and long lasting
Here are some of the strength properties of chlorinated polyvinyl chloride (CPVC):
  • Tensile strength: Ultimate tensile strength is 1310–11600 psi, and yield tensile strength is 7020–8410 psi
  • Elongation: Elongation at break is 15.0–650%, and elongation at yield is 2.30–7.00%
  • Working max pressure: Schedule 40 CPVC has a working max pressure of 450psi
How long have you been using it?
What glue and primer did you use?
Have you protected it from welding and grinding sparks?
   / Garage Air Mounted Lines #9
I thought there was a concern on the oil from air compressor potentially degrading PVC over time.
Aluminum tubing is becoming a popular option today since lighter than black pipe and doesn’t rust
   / Garage Air Mounted Lines #10
Rebeldad1,
Those ratings you specify are very diameter and temperature dependent. As the dia gets bigger the ratings, especially the pressure ratings, drop.
The following link is to temperature derating for CPVC. If you see 120'F, a hot day, in an enclosed space the CPVC gets derated to 0.65 of working pressure at 80"F. I'm personally not a fan of plastic for air pressure systems since they shatter when stressed. Sweated copper is my preference and threaded black iron as 2nd go to. Both can be used in long unsupported runs without sagging and thus prevent water ( condensation ) accumulation whereas plastic sags and is harder to keep dry. Personally, I place a "T" in long runs and a leg that catches condensate and can be bled off.
Plastic fittings have their own pressure ratings which may cause system derating due to being weak link and plastic lines need protection from blows and crushing as plastic does not tolerate these.
For grins and giggles, here is copper pressure rating by size.
Sweated copper tube an fittings is very robust and retains its rating even when suffering minor damage such as squeezing or minor crushing.
My last word is the following link that provides guidance, dated 12 July 2024, from OSHA on use of plastic pipe.
DIFFERENTIAL ASSEMBLY (A55745)
DIFFERENTIAL...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
