Box Scraper gannon landscaping Blade
   / gannon landscaping Blade #1
wrencher42
Arnold MD
cub cadet 7305
Hello I am looking for info on how the tineys on a Gannon H-220 stay up I will try to add pic thanks Bill
   / gannon landscaping Blade #2
Well, now - - from the pictures I could find. It appears that when the tines are in a notch - either full up or in one of the two down position - there is some sort of something behind the tines that holds them in the notch. This would keep the tines from moving to the rear and falling out of the notch. I could not find a picture that showed what that something might be - a bar - some sort of lever or a pin???? If it is not obvious on your unit - it could be a missing part or parts.
   / gannon landscaping Blade #4
Wow!! Gotta say - that's a lot more complex than my Bush Hog RO720 setup.
oosik thanks for your answer , so you push the tines up in the notches then the tines float?
thanks Murph1 that's where i got all the parts there a great business
yeah i bought all the parts from Messicks just trying to figure out how it all works !!
   / gannon landscaping Blade #8
If your Gannon is like the spec drawing that Murph1 linked to - its a LOT more complex that my Bush Hog. Mine just has a pin that goes thru a hole and tabs on each shank. I think there are four holes in the shank. Just lift it up where you want it and run the pin thru a tab on each side of the shank and the shank.
That drawing show a fairly sophisticated locking system. Whatever - if you have all the parts its just a matter of figuring out the arrangement and getting them all together. Easy to say...........
   / gannon landscaping Blade #9
Its a spring type thingamajig
Yeah I think it is like Murph said
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Informational Lot - Shipping (A53472)
Informational Lot...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Payment Terms (MUST READ) (A50775)
Payment Terms...
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
John Deere 2155 Tractor (A51573)
John Deere 2155...
