Box Scraper Gannon box scraper
/ Gannon box scraper #1
Dan Argento
Camarillo, CA
Kobota B7100 Manual
I have a Gannon EK 1 box scraper. Can't seem to find Gannon on the internet. Think they are in Calif. Would like to get a manual.
/ Gannon box scraper #3
Woods (gannon is a sub of woods) does not have good specs on the attachments on the web site anymore. They used to.
jb
Thanks for the info. I am trying to determine if my 16HP B7100 Kobota can handle the Gannon EK 42-1.:confused:
/ Gannon box scraper #5
No idea. How wide is it? How much does it weigh?
Your tractor is probably limited to 42-48" and 300 pounds. Just a guess, but probably close.
jb
/ Gannon box scraper #6
If you have the scraper and the tractor why not just try 'em out and see how you like the job it does. If the tractor's front end stays on the ground then it's not too heavy and if you can't bend it on rocks then it's all good. :)
It is 42" wide. Not sure how much it weighs but I don't think it is over 300#'s. I will give it a try.
/ Gannon box scraper #8
That should be OK for your tractor.
You may want to add more weight to it as you get comfortable with it, but that is optional based on performance, soil, etc.
jb
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Railroad Maintenance Machine (A61570)
Railroad...
2013 Ford F-350 Pickup Truck, VIN # 1FT8W3BT5DEA61959 (A61165)
2013 Ford F-350...
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-1930...
