Game Camera with Cellular
/ Game Camera with Cellular #21
But I'm interested. What is this "centralized cellular modem setup". Is there a unit (for example on Amazon) that does this? I would be *very* interested.
I use a CradlePoint MBR95
and an AT&T Beam 4G LTE USB modem plugged into the Cradlepoint's USB port
with this external antenna connected to the modem
to have the cam in this image:
provide this image:
(and others similar from around the property)...
Example video from that camera:
/ Game Camera with Cellular #22
Have used mbr95 setup also. sent over 75000 pics offsite using it with 1 camera.
/ Game Camera with Cellular #23
I first learned about them when tasked by the local transit authority to put wifi internet access on the buses they use on the 1.5 hour trips to PIA. They seem to hold up well under some pretty grueling conditions. The weakest part of them seems to be the power connector.
I also like it around my place because my cell phones don't reach at ground level (sometimes I'll get one bar long enough for a text or email to come through). Having the Cradlepoint connected to the USB modem with the external antenna routed to a place good signal is received gets me internet to the farm. I may not have actual cell service, but I use email more than text, and I have a landline, so it works for me...
I use the wireless access point in the Cradlepoint within the main house, have one of the LAN ports connected to a Trendnet powerline adapter, and have 4 other Trendnet powerline adapters in other locations. On each of those powerline adapters are Ethernet switches of various sizes, with various network devices, computers, cameras, printers, and whatever else is needed connected to the switches. Also connected to the switches are several wifi access points, some of which are set to separate channels and operate on the same SSID as the Cradlepoint (making one large wireless network that covers an area greater than any one access point could cover). Other access points are dedicated to linking with a wifi Ethernet adapter to provide service for some of my more distant cameras.
I am in the process of setting one up to work solely from solar power, Wireless Ethernet adapter, Power over Ethernet adapter, and the IP camera. I'm busy with other projects, I left off in calculating my nighttime battery capacity needs.
/ Game Camera with Cellular #24
I like the wan over wifi. I now use my mifi with it, plus satelite internet so i can use eithersource. i no longer use the usb modem.
Also use ip over powerline for my barn camera.
Can watch any of my ip cameras on my phone.
/ Game Camera with Cellular #25
They have a larger model, the MBR1200 I think it is, that has 3 USB ports a PCMCIA slot, does the WAN over wifi, and dual Ethernet WAN providing the possibility of up to 7 connections for load balancing or failover. Really good stuff.
/ Game Camera with Cellular #26
This is sounding like something closer to what I am looking for
2015 HCO Spartan GoCam No Glow Verizon
Tom, did you ever decide on one? What you are describing is kind of what I am looking for as well. But I am looking for an even more self contained setup, possibly powered by a solar panel. We live in Montana, but our property is in Ohio. With technology evolving the way it is, it seems definitely possible to find a tech solution for this type of application that would work, and work well. We don't have anything pilferable necessarily, except maybe trees...or multiflora haha, but it would be nice to have a general idea of who or what, if anything, is on our land.
1454 (A57192)
1454 (A57192)
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
DITCH WITCH JT60 ALL TERRAIN HORIZONTAL BORING MACHINE (A60736)
DITCH WITCH JT60...
