gabem1
   / gabem1 #1
gabem1
I just got a 2009 s 250 . happened to have a local bobcat road tech looking at another 250 he checked codes a said all looks good ,put it to work that day ran a plainner no problems the second day ran for a few hours and got a acs8103 code and could not move the plainner left or right .Got it back to the shop did some basic checks battery 7-way conector that runs the attachments all pins were ok. then the machine now works fine only ran for half hour.Does anyone have any sugjestions.
Thanks Gabe
   / gabem1 #2
I have limited experience with a planer, but had a similar problem with the planer we used. I ended up tracing the harness from the planer to the machine and found a chafed wire that was causing the problem.
Good luck,
Brian
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
Scag Mower (A50324)
Scag Mower (A50324)
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
