G6200H Won't go forward any more, GOES in REVERSE just fine, Please HELP!
   / G6200H Won't go forward any more, GOES in REVERSE just fine, Please HELP! #11
The reason you found very little is that they rarely have problems. I would take the fenders off and do a little more testing before ordering parts.
Best of luck
UPDATE:
Well I plunged into it over the weekend! Removed the Hydro pump from the machine and tore it down. ONLY MY LUCK, I got one made at 4:00pm on a Friday I suppose!
There are two plugs that are in the end of the Pintle Assembly shaft (that I presume were there so they could drill the passages thru the shaft during manufacturing). Well, one of the plugs backed itself out of it's threads thus opening another avenue for the fluid to travel(In the wrong direction). The R&R manual tells you NOT to remove these plugs, so I presumed that they should have been lock-tited originally. They weren't! So, I re-installed the backed out plug with some lock-tite and then removed the other plug and lock-tited that one in as well. Put everything back together and HURRAY, it goes forward and backward again!
I wish I could have accomplished all that work as easy as I just made it sound!!!!!!!!
Thanks for the help and If anyone ever has any questions on Model 11 Eaton pumps, I'm your man now!
Frank
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
ABO TANK (A50854)
ABO TANK (A50854)
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
