G6200 Fan Belt Replacement
   / G6200 Fan Belt Replacement #1
wwr1964
Columbia Tennessee
Kubota G6200
Can anyone shed some light on how to change this belt out. Cant figure out how to take apart where engine and drive pump meet.
:confused:
   / G6200 Fan Belt Replacement #2
I don't know how to break this to you.
You should be sitting down.
If I remember correctly, you're going to have to take the drive shaft off or separate the flex coupling.
Here's what you'll see when you get the drive shaft & flex coupling off the pulley:
I discovered this after replacing a shaft with a worn out spline.
After I got everything reassembled I realized I hadn't replaced the fan belt.
There was a few minutes of head scratching before I realized that I had to take that shaft back out if I was ever gonna get that belt on.
Doh!
If you replace that belt make sure you get a good quality replacement that will last a while.
   / G6200 Fan Belt Replacement #3
What Baby Grand said, and for sure don't get the screws 130 and 140 mixed up, they are different length and will offset the drive shaft and cause it to vibrate.
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
Massey Ferguson 9250 (A53472)
Massey Ferguson...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
