G4200 Glow Plugs
   / G4200 Glow Plugs #1
kevinc419
I was recently given a G4200, and I have no experience with diesel engines - just gasoline. I had it running and after rebuilding the mower deck and reassembling, I could not get it to restart. It's blowing lots of white smoke - which I believe means air - and a squirt of ether will get me a few revs. I check that fuel is being delivered to the injector pump, but do not know what voltage should be present at the glow plugs for proper operation. I bought the Kubota workshop manual, but find it miss lots on info that I would like to have. Anyone got any info to help me? Also, any diesel how-to book recommendations would be appreciated.
Thanks,
   / G4200 Glow Plugs #2
I cannot help you with a manual. Unless you go to a dealer. Or try Tractor Smart.
<font color="blue"> and a squirt of ether will get me a few revs </font>
Spraying <font color="red">ether </font> in a modern diesel, can <font color="red"> damage </font> the engine.
   / G4200 Glow Plugs #3
White smoke with a diesel usually is unburnt fuel, often found when starting a cold engine. Cold diesel engines, particularly indirect injection ones, use some form of starting aid to get them running. Diesels work by compressing air inside the combustion chamber. Air gets very hot when compressed a lot. In a diesel, it gets so hot that when diesel fuel is injected into the combustion chamber where this very hot air is, it ignites on it's own. Hence, no spark plugs in a diesel are required.
However, cool air is drawn into the engine when the engine is starting/running, and when the engine is cold, it needs a bit of help getting the air from ambient temperature to the 500C or more it gets to for ignition. Glow plugs are small heating elements that heat the air in the cylinders (pre-combustion chambers on indirect injection) to aid starting. Very important things, those glow plugs.
All glow plugs I've dealt with use battery voltage, typically 12 volts. Some only need it for a very brief time, like the ones in my truck, for a 3 second blast. Any more than that and I risk burning them out (done this twice now. Ouch $$$). My B6100 can be glowed for up to 60 seconds. Also very important is a strong battery. You can wind a diesel over all day, but it will never start if it isn't spinning fast enough, like a half dead battery would do. Also, the glow plugs draw lots of power, so a good battery is needed. Ether is nasty stuff, as it burns VERY hot and burns easily, so not only does it threaten to burn pistons, it wants to burn too soon, hard on bearings (that's why a loud knocking from ether start-ups).
I hope this helps. Sorry for such a long answer. /forums/images/graemlins/tongue.gif
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
