G3033 rear remotes
   / G3033 rear remotes #1
Ym155d
Magalia, Ca
Yanmar 155d
I am trying to set up rear remotes on my G3033. It listed it as an option when I bought the tractor, but I did not think anythng of it then. What is the factory location for connections when assembling rear remotes? It lists as an option and I see in the manual a second distribution block which has lines coming out of it toward the filters. There is an a bolt...maybe a plug with "G2" next to it I believe. Anyone know if this would be the port I need to use a pressure out port to feed a remotes valve?
   / G3033 rear remotes #2
i believe mine is under the seat, will have to look when I get home
Thanks, that'd be awesome...if you could take a picture or if anyone has pictures that'd be great! I already have my front remotes close to plumbed, now working on rear. I didn't want to have to plumb the PB port all the way back to rear and then come back twice with a Return to tank and PB from valve to original port on distribution block.
   / G3033 rear remotes #4
Sorry, it was really late when I got home, I hope these come out well enough to make it out, if not I will take them again in the daylight.
Thankyou AZRANGER ...Yep, just how I suspected they were. I researched online and found a pdf of the remote option...I wanted to insert the file into here so others could see, but I counlnt save it or copy it. I callled the dealer and I am going to buy the remote optional kit. Kinda stinks after I already bought a triple valve and a bunch of fittings. I am super stoked to get it though...supposed to be in Wednesday. I have hydraulic rippers on my box scraper that a want to try out. I also purchased 17 hydraulic rams at an auctions I can use to build anything I want...I will probably only use a few of them and sell the rest.
   / G3033 rear remotes #6
I want to add a hydraulic cylinder as a top link on my box blade , that way I can adjust the pitch on it. Post some pictures when you get it set up.
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2014 Ford Taurus (A56859)
2014 Ford Taurus...
