G1900 Charging Problem
/ G1900 Charging Problem #1
Dunkirk, Maryland
New Holland TC40DA
Having charging issues with my g1900. Getting 30v AC from the alt and 12v from the key switch to the regulator. Just no output from the regulator. I bought a new regulator but has the same issue.... Unless the new one is DOA.... Kinda stumped. What else could it be?
/ G1900 Charging Problem #2
If the battery is fully charged the regulator will shut down till the battery needs more power.
I've ruled out the regulator and the alternator or whatever its called on these. Still have the no charge light on the dash and no 14 +/- volts coming from the regulator. I guess I need to check the wiring from the regulator to the battery. Does it by any chance go to the black box? Maybe that could be my problem. IDK... Still stumped.
Fixed it! Simple as a fuse not making good contact. lol
Now to fixing the temp and fuel gauges.
/ G1900 Charging Problem #5
I have a G1800 that I had the fuel/temp gauges not working, I just pulled the wires and cleaned up the connections and they came to life. However remember there are 2 temp sending units on these tractors one is right up by the radiator cap (when this one is grounded all it does is set off the buzzer that's designed to be a fail safe.) The other is on the front of the engine almost in line with the injectors. Clean them up and see what happens!
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
1986 Military MEP 0006A 60kW Towable Diesel Generator (A59228)
1986 Military MEP...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
