G1800S Hydrastat Pedal Linkage adjustment?
   / G1800S Hydrastat Pedal Linkage adjustment? #1
philav8r
The hydrostat control pedal has lost control of changing speeds or direction. Its as if the linkage has become disconnected, but its not because there is a wee bit of on/off control in the reverses direction.
I am able to drive the tractor in the forward direction with the speed control on the right hand side rear fender.
Any suggestions where to look for a solution? Is there an adjustment somewhere?
Found the problem. There is a pin through the pedal shaft which fixes the shaft to a lever arm which activates the linkage. For some reason the pin had worked its way out. Couldn't see the problem until I removed the mower deck and crawled underneath to have a closer look.
Ordered a new pin from Kubota.
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
