G1800S Hydrastat Pedal Linkage adjustment?
   / G1800S Hydrastat Pedal Linkage adjustment? #1
philav8r
The hydrostat control pedal has lost control of changing speeds or direction. Its as if the linkage has become disconnected, but its not because there is a wee bit of on/off control in the reverses direction.
I am able to drive the tractor in the forward direction with the speed control on the right hand side rear fender.
Any suggestions where to look for a solution? Is there an adjustment somewhere?
Found the problem. There is a pin through the pedal shaft which fixes the shaft to a lever arm which activates the linkage. For some reason the pin had worked its way out. Couldn't see the problem until I removed the mower deck and crawled underneath to have a closer look.
Ordered a new pin from Kubota.
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
23222 (A50323)
23222 (A50323)
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2012 FORD 4 DOOR TAURUS SEDAN (A52576)
2012 FORD 4 DOOR...
