G1800 Smoking and dead cylinder
   / G1800 Smoking and dead cylinder #1
NickJD300
JD 300 Industrial
Good afternoon,
I purchased this G1800 about a month ago based on the fact the engine ran great.
1000 hours.
Previous owner was hard on it honestly.
I began fixing things like the mower deck wheels and purchased filters etc.
Then all of the sudden it quit running on one cylinder and started smoking.
I had taken the air filter out to clean it and when I started it to move it into the garage without the air filter in it, it started smoking like crazy. The smoke appears to be blue and I included a photo.
Ill also say that at that same time, I added about 3 cups of coolant to the overflow canister.
I have tried running it with the air filter, changed the injectors from cylinder 1 (the dead cylinder) to cylinder 2, also changed the injector pump mechanism from cylinder 1 to 2.
I installed new fuel filters. I am not getting any bubbling at the radiator cap. The oil level appears to be rising slightly.
Does anyone have any suggestions or checks before I tear the head off of this thing? I am about to buy a compression tester for diesels this afternoon.
   / G1800 Smoking and dead cylinder #2
The smoke looks white from here. Which would occur if a cylinder was not firing. That might also explain the increase in oil level--The crankcase is filling with diesel.
My best guess at the moment would be a valve on the dead cylinder. Pull the rocker cover and see if the valves are moving. If they are, then it's probably a burned valve.
Thanks for the suggestion!
It could be white. I took of the rocker cover and confirmed the valves are moving.
The pressure tester I bought did not fit the injector or glow plug port.
I have changed the oil today to monitor the oil level. No metal in the oil.
If anyone has any further ideas or suggestions, let me know.
   / G1800 Smoking and dead cylinder #4
Shouldn't have changed the oil yet. It's not fixed! Don't run it like that. :confused:
While you have the cover off, check the valve lash. A burned valve will mostly likely be tight. (They accumulate carbon under the seat.)
EDIT- I should have said exceptionally loose. Carbon under the valve keeps it from seating making the clearance measure huge.
The other possibilities are a broken ring or a broken rod. (I have one of those 3-bangers here with a broken rod.) The next step is to pull the oil pan and see if all the rods/pistons are still intact. Look up inside and make sure none of the pistons are cracked. Check the cylinder walls for scoring.
   / G1800 Smoking and dead cylinder #5
Probably sucked a bunch of dirt into engine because you ran it with out an air filter. Most likely broke a ring or scared cylinder
   / G1800 Smoking and dead cylinder #6
Did you try swapping the injector on the dead cylinder to a different one?
Thanks for all the input here guys.
Bravo - I did try swapping the injector - and that is a great suggestion in this type of situation.
Powerstroke - I do not believe it sucked in a bunch of dirt when I moved it 20 yards without the filter but you do have a valid point.
Tinhack - The valve lash on the dead cylinder was within spec on the intake. All 3 cylinders were loose on the exhaust ~.014
The factory spec for valve clearance on intake and exhaust is .0057 to .0073 inches.
Compression readings are 150 on the dead cylinder, and 250 each on the others. I welded a gutted glow plug to a nozzle that fit my compression tester.
When I take an air nozzle and inflate the cylinders, I can see and hear bubbling oil around the valve springs.
I will move forward with getting the valves to seal and a new head gasket. Let me know any thoughts or suggestions that you have.
Well - theres my problem.
Still gonna lap the valves in and replace the head gasket. Not too sure how accurate my compression tester is.
Thanks all, for your time.
Anyways.. onward.
   / G1800 Smoking and dead cylinder #9
enlighten us. looks like it sucked a rag into the intake but what is that part with the rag in it.
   / G1800 Smoking and dead cylinder #10
Where the heck did the rag come from ???? Did the OP stuff it into the intake to protect it while the air filter was out and forget about it ?
If airflow into the cylinder is restricted, then the compression test will be low because the engine wont get a cylinder full of air to compress.
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
