g1800 gauge prob fix
   / g1800 gauge prob fix #11
A friend gave me his G1800 that needed lots of TLC. In the process of getting it ready for use I discovered the fuel and temp gauges stopped working. This unit also has a secondary starter button added since when you turn the key all the way to the right to start it didn't engage the starter. I have discovered that once in a great while the ignition switch would crank the motor. I sprayed some electrical contact cleaner into the key switch to see if that would help the switch engage the starter. Well, right after that I noticed the fuel and temp gauges stopped working.:mad:
I will see if the needles are stuck as happened to Phil Murphy and Texwing. Hey, I have found 1 fifteen amp fuse under the screen covering in the cab and that looks to be working properly. Are there any more and if so where are they?
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
