G1800/G1900 front PTO RPM?
   / G1800/G1900 front PTO RPM? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
Does anyone know at what RPM does the front PTO of the G1800/G1900 turn?
I want to connect a two-stage hydraulic pump to mine to run a log splitter. The pump is designed for 3600 RPM, so I'll probably need a increase the speed with pulleys. It is a 28GPM/6GPM pump, and requires a 13 HP engine, so the 16HP on my G1800 is about right. I plan on using quick-connect fittings, so that I can connect this in place of the 8HP/16GPM setup on my splitter, but yet still use the splitter stand alone. This way, I get a much faster splitter at home, but can still take splitter somewhere else w/o requiring the tractor.
I had considered a 540-PTO pump on my B7100, but those pumps all seem to be single stage.
Thanks,
Jay
   / G1800/G1900 front PTO RPM? #2
Best of luck with your project,here in Ireland and wishing to do the exact same with same machine,
   / G1800/G1900 front PTO RPM? #3
Should be 2000rpm
   / G1800/G1900 front PTO RPM? #4
Thread from 2009...OP last seen 2019 it says... :rolleyes:
   / G1800/G1900 front PTO RPM? #5
Yeah, but might help the person that just posted, or anyone else that searches.
Always hate threads that don't have a resolution.
INOP/NON-RUNNING 2005 Toyota Prius Passenger Car, VIN # JTDKB20U253038319 (A51572)
INOP/NON-RUNNING...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
