FX22D Tire Size
   / FX22D Tire Size #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV 900X Mahindra 4540 4WD w/Loader
The fx22d I just bought has 11.2x24 rear tires and 7x14 tires on the front. Anybody know if this is the correct sizes. I like the tractor and considering replacing my ym2002d with it if I can locate brackets to put my koyker loader on it off of my ym2002d.
   / FX22D Tire Size #2
I don't know but can tell you the parts manual for an FX24D shows 11.2-24 and 7-16 tires. Over in the back of the manual where it starts showing options it shows a different front axle and 7-14 tires and rims. No idea why it shows this option. My Japanese is nill.
Take a look at this. https://www.machinefinder.com/ww/en-US/machine/1986889
I have probably just muddied the water for you.
   / FX22D Tire Size
Well still not sure about the tire sizes but the 4wd shifts smoothly and has no binding so I am hopefully OK. There is a small push button on the right side of the light switch. Anybody know what it's for?
   / FX22D Tire Size #4
Shows to be a horn button on an FX24 parts manual.
   / FX22D Tire Size
Maybe! There is a button on top of the light switch that has an horn on it so I assumed that was the horn. Neither work. I've been reading a little about parts availability on the FX models so I'm still not sure if I want replace my ym2002d with or not. It sure runs smooth and operates nicely. I am going to check out the loader brackets and see if I can get them. I can't do without my loader.
   / FX22D Tire Size #6
You probably already have one but if not I would strongly advise an over run clutch for the pto on your FX. That size FX's have a history of ring and pinion problems. Are you thinking of taking the loader off your 2002d? If so, I would think a metal fab shop or some such should be able to fabricate new ones or modify your existing brackets to fit your FX.
   / FX22D Tire Size
I do have a over run clutch but I have never used it on my ym2002d. I don't have a bush hog. I use it mostly for a finish mower and a tiller. It would be nice to have another set of brackets and use the loader on which ever tractor I choose. I might sale both of them and get a larger ym model.
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
1999 24DTA pintle hitch trailer (A53472)
1999 24DTA pintle...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
